Drove last night, all was fine. This morning it is acting crazy. Break is heavy, won’t shift and acts like it starts and cuts off. See video to see what is happening. Tried a jump and didn’t work.
Starting video
Yes, if it's the original battery, I would be shocked that you made it this long. If the battery has been replaced with an aftermarket, check terminal connections. Some after market batteries are about 3/16 in shorter, not allowing battery post to come through the battery box top far enough. This problem does not allow the terminal to go down over the post far enough to be tightened properly. If that checks out, you may be looking at a bad ignition start button.
Any update on this? Ty
