My 2016 Pilot tailgate opens, but won't power close. It started a while ago with warning on the dash and started working again and waring disappeared. Now it started again, the tailgate won't close and I get the " problem with the tailgate" on the dash. Do you think it's the Motor for Tailgate or sensor?
https://www.hondapartsnow.com/genuine/honda~motor~set~74961-tg7-315.html
or sensors?
When my '12 performed this same way it was the tailgate switch. That's the piece that houses the close button on the trunk. It started out intermittent and then became permanent until I replaced it.
Hey JcKobe, did you fine a fix for the lift gate?
I have the same issue. Opens under power from door button, key fob, and button by the license plate. Pushing the button on the lift gate will not close.
