1 - 2 of 2 Posts
Looking to see if there's a way I can adjust the rain sensitivity setting on a 2016 Elite. Recently had the windshield replaced with OEM glass by the dealership. All functions work correctly, such as LKAS, however I've noticed that the rain sensing wipers are no longer functioning as they were before. Even with the dial on the most sensitive setting it takes a lot of rain build up before they will activate. Is there anything I can try before going back to the dealership?
I only see one place to adjust, which is the right hand side knobe. You may try the two extreme positions to see if it make any difference, by turning the knob. I believe it only works when you push the handle down one click (the first position, or the variable speed setting). All other positions don't have rain sensitive, at least that's how it works on mine.
1 - 2 of 2 Posts
