1 - 10 of 10 Posts
We only wanted Android Auto, HondaHack solution was just not enough.First I swap out 2017 EX Audio Unit part #39540-TG7-A02 just to get Android Auto working. Then I came across a great deal on a 2018 Elite Audio Unit part #39540-TG7-A44.
After installing the unit, I found that there's no sound since EX trim doesn't come with an AMP.
I couldn't find any information on anyone else who added OEM Rear Entertainment System to Non-Elite/Trg trim. So I took the dive and did the whole audio system upgrade!
In between work, distant learning for the kids, a few hours a week, and plenty of frustrations, I was able to gather all the necessary parts, diagram, and pinouts for the project.
Necessary OEM parts can be had on ebay:
1. 2017-2018 Audio Unit w/ RES
2. AMP
3. BluRay Drive
4. Dash Harness from Elite/Touring
5. Rear Screen (dual HDMI for BD)
6. Rear AUX Jack
The rewards was Android Auto for the happy wife and rear Entertainment for the kids!
here's a few pictures of the process:
141995
141996
141997
141998
141999
142000
142001
142002
142003
142101
Wow, great job. I could never dare to attempt something like that. One additional thing I would have done is adding sound sound deadening to make the Pilot more quiet. Awesome job.
Very cool! Tons of work but I respect that. Did you have to pull the dash?
Sent from my SM-G960U1 using Tapatalk
Discussion Starter · #4 · (Edited)
I did not pull the dash. Instead I cut and splice Audio connectors from Elite trim harness and ran the wires behind glove box up to the front pillar.
Looking back now, it would've been easier to pull the dash and swap the entire harness.
I just wanted to keep everything intact for the original EX harness in case things didn't work out.
Fortunately, I didn't break anything major beside a blown fuse (backup fuse illumination for Rear screen).
Impressive work!
I have a 2016 EX-L without RES, but I added a screen and hooked up my old Playstation 3 as Bluray drive under the front passenger seat. It's fed by a 12V DC to 220V AC inverter hooked up to the 12V outlet in the centre compartment. Works perfectly. The only downside is that I don't have Andriod auto or Apple Carplay. But the install took maybe 5 hours. 4 for the screen and 1 for the inverter/PS3.
My plan is to make a complete rebuild of the sound system in the car. Removing all speakers and replacing with good ones, adding a second head unit somewhere and adding DSP controllers and amplifiers, as well as noise damping the car. But I have no idea of when I'll have time for such a project anymore...
Discussion Starter · #6 · (Edited)
Impressive work!
Aftermarket would've been a much easier and probably better solution, but i just love the look of OEM setup.
I rerouted the center HDMI jack to the overhead screen for safer connection such as Chromecast or Roku stick. Kids keeps kicking the bottom jacks.
142024
142025
Dedication!
1 - 10 of 10 Posts
