Got a P0685 code and need to replace the PCM relay. I cannot find a diagram showing where this is located. I'm not the most mechanically inclined but figured this would be simple enough. Maybe it goes by another term or name I just don't know.
I found that with the accords they are under the dash but from what I found is the fuse locations but they don't seem to list what relays are. I found this but don't see it listed: 2009-2015 Honda Pilot Fuse Box Diagram (this was my initial post and questions, but I did find more information see below)
I found somewhere that these are called PGM fi1 and PGM fi2(found here, assuming this would apply to my vehicle ECM Relay Location: I Need to Know Where the ECM Wiring Relay Is ...). Would that be accurate? If so, I found where these are located, from the previous link outlining the fuse boxes. However I have 2 questions.
1. How do I know which one it is. Also the code seems to have cleared, should I just leave it for now until it comes back?
2. If not, question 1 again, how do I know which one it would be.
Thanks in advance to anyone that can help me with this.
Gird your loins for the cost of these relays...and as D. Bob would say, replace the relay(s) rather than run with scissors, like I did.
