1 - 2 of 2 Posts
Anyone have step by step on how to do a front right cv axle replacement on a 2015? Any help would be appreciated!
Same procedure ..make sure you get the list of the correct torque specs for the axle nut and bolts . impact gun helps a lot ..one of the problems I ran into personally is that when buying the part
the "new" part was an inch shorter than the original they need to be exact and also the speed ring may need to transfer over to the new shaft DO not kink it in any way..watch out for the ABS sensor in there ..they are extremely moody and sensitive they could or will break if caution is not taken. a long bar with the angle tip helps to pop the axle out.
YouTube
1 - 2 of 2 Posts
