1 - 8 of 8 Posts
Hi, I have 29K miles on my 2015 Pilot SE, so far the car has been flawless, I just moved to Sarasota, I called the 2 local Honda dealers, one quoted me $350 + tax and the other $590 + tax, I really don't trust them, I would prefer a local mechanic, any recommendation? Thank you
What are you having done?
30K service:
Replace engine and differential oil replacement, break fluid, maybe automatic transmission fluid as well?
Inspection of brakes, fuel lines, etc. and check all the other fluids. I would say, pretty basic.,
I purchased Honda Care, I want to be in compliance with Honda.
Miss our 2005 Pilot
Were the two quotes for the exact same services?
While I don't like taking the vehicle to the dealer, while you're under warranty sometimes you're better off just taking it there. If an issue arises they can't blame the independent mechanic for causing the problem.
Correct, exact same service
I mean assuming all is the same, and you want to go to a dealer go with the cheaper one.
Other than the brake fluid, the rest of those fluids can easily be changed on your driveway without even lifting the car.
1 - 8 of 8 Posts
