If it has navigation, the amp is under dash, all the way on the right side.
Otherwise, the amp is built into the audio head.
Are you sure about that ? reason why i am asking is that I'm thinking of replacing the HU .. so technically if this was the case then there should be two lead wires coming from the Subwoofer then . :) makes life easier :)
Thanks for the info!
Not entirely sure what you mean by "two lead wires". Yes, sub got two wires (+ and -) going to it, but on nav models, those wires start at the amp, and on non-nav, they start at H/U.
