2015 Honda Pilot Ex-l 4wd modern steel metallic
So it seems my Ex-l has DRL. I thought there was a light on the dash that showed this. At least on other make cars I've seen this. There's no light on dash showing I he them I just noticed the lights were on when the switch says off.
Correct. It's the high beam bulb on the Gen 2.5 using PWM (pulse width modulation) that basically runs the bulb at 6V, so half the brightness. Some brands allow you to disable the DRL, Honda does not. If the bulb burns our I believe you will get a DRL dummy light.
Just so everyone knows what is being discussed here. DRL = Daytime Running Lights
What???..........Wait!!!......You mean the Pilot doesn't have a Descent Rate Limiter?
