Got a 2015 with an A13 code. Planning on doing the fluids this weekend. Just wanted to double check on the crush washer sizes.
Oil drain plug: 14mm
TX drain: 20mm
TX fill: 24 mm
Transfer case drain and fill: 18mm
Please correct me if I'm wrong! Also, does the inner diameter differ from any normal crush washer I could pick up at O'Reilly's?
TX drain: 20mm
TX fill: 24 mm
You may want to compare the thickness of the washers aftermarket via Honda.. what I found was the ones from pep boys , autozone and advanced auto was not as thick as Hondas..
