1 - 2 of 2 Posts
Any suggestions or feedback regarding lifting vs. leveling a 2014 Touring 4WD model? Most threads are years old at this point. Visited a local 4WD shop today and they didnt have a lot of information as this is not a common vehicle to lift. Open to any options to gain a few more inches of clearance and taller tires Thanks-J
Welcome to the forums , Alot of the info you found is correct.. This vehicle class is NOT designed for the iron hearted trail riders. There are a few kits that would allow spacers to give you a max of 2" nothing much more than that .. The CRV model I found has a lift kit that can /could fit the Pilot with some modifications. There are members here that have done the lift kits that you seek..hopefully they chime in and give you the info that your looking for. With any of the kits that are installed they put much more tension on the front axles and in turn leads to quick premature wear.
If your fine with that like some members are there are options ... best of luck to you in your quest!
1 - 2 of 2 Posts
