Some guy on FB marketplace is selling 4 2006 Ridgeline RTL rims for $60. I checked the specs on the rims and they look like they match my 2014 Touring size @ 18x7.5 and 5x120 pattern. However, when I look on tire rack the tires are slightly different @ 245/60-R18 vs 235/60-R18. Will these rims fit my current tires? Also, will the rim fit under the car where the donut sits?
I think that the 06 had a 5-4.5 bolt pattern. Wheels may not work. But a full size tire does fit underneath.
Edit: 05 is where they switched to the 120mm pattern. 04 and older is 4.5"
Ok so I ended up buying the rims off the guy for $60. They're a little scuffed up but since I'm using them as a spare I don't really mind. I might actually use them as winter wheels later on. I got the tire mounted on the rim and it fit just fine. Over the weekend I lowered the donut, removed the donut plastic spacer underneath and hoisted the full size rim up under the bumper. It fits great and will definitely come in handy on an upcoming 3k+ mi road trip to Colorado!
Is it supposed to face with the inside down?
