1 - 11 of 11 Posts
Hi I am aware that I can't easily replace my headunit so I am not going to lol. Just wondering if I would notice any improvement by replacing the speakers?
Thanks!
Thanks I was just worried that i wouldn't be happy and end up spending a fortune. Should i go with component speakers up front or just regular coax?
Interesting question. On lower trims, there is a single pair of wires going out from audio unit/factory amp for each front. Tweeters are simply wired parallel to front woofers and wires branch off to the tweeters in rather inaccessible spots. With arrangement like that, one is far better off disconnecting dash tweeters and going with 2-way coax in-door woofers handling both mids and highs. Lower trims have a different model tweeter which, I believe, has a built-in high pass filter. Installing a component system properly here would require complete rewiring of the fronts.
On a touring, there are separate wires going out to tweeters from the amp, so I would imagine, factory amp handles the crossover and feeds mids to door woofers, and highs to the tweeters. A component speaker system comes with a crossover box that takes a single input and splits the signal out to woofer and tweeter, and is kinda tuned to specific frequency ranges of those. Technically, you can get a component system, replace tweeters and woofers, and just leave the crossover boxes unused. Another option, get separate speakers for your doors, and separately, a pair of tweeters for the dash.
Thanks for the information! I think I will just buy separate door speakers and tweeters.
My stock 2017 sound was horrible. I replaced the doors with focal two ways and it was a huge difference. Wife even noticed
Which Focal model did you get? Also, since it's two way, did you keep the factory tweeters or disconnected them since Focal already have them?
I just ordered the Infinity Primus PR6512is from crutchfield.ca for $124.99 are these any good with the stock system or should I be looking at something else?
144878
I left the stock tweeter for now. Might upgrade after some other projects. Sound is much better. I had to dremel some of the inside door plastic for them to fit flush. It went pretty smooth.
I've had infinity in the past and really liked them. Anything will be better than the stock. I have a 2017 and not sure if ull need to dremel
1 - 11 of 11 Posts
