Anyone ever replaced a knock sensor on a second gen pilot? Or anyone have service manual instructions for the replacement of it?
Thanks in advance.
Discussion Starter · #2 ·
Follow up on my original post: looked like a mouse had eaten my sub wire from the main harness to the knock sensor completely through. The sub wire had to be purchased from
Honda for about $15, the knock sensor I got from an auto parts store for $20.
I spent about 3 hours taking everything apart, and 2 hours getting it all back together. On the tear down, probably half the time was spent trying to figure out if I could get to the knock sensor without removing more and more stuff. I ended up having to remove the intake manifold, injectors and fuel rails, and even the power steering pump to get to one bolt on the lower intake manifold.
Attached is a pic of the knock sensor and it’s location in the valley. Note the subwire is not connected in this picture.
133004
so this sensor is located under the plenum?
The J35 has such a nice open and warm spot under the intake plenum for mice to build their nests. Spent a good deal of time with a flexible grabber pulling hood/firewall insulation out from under the plenum on my brother-in-law's Odyssey when we replaced the timing belt.
