I have a 2013 Honda Pilot and now it’s the third time that all the dash lights flash on and off and the warning buzzer dings as well as the headlights dim and go bright..Has anyone had this problem? The battery is less than a year old..all ground and battery connections are good..perhaps the alternator although I’ve checked it and it is putting out over 14 volts so that seems normal..
Seems like intermittent loss of contact from the alternator. How often and in what circumstances it happens? Do you have an ODB2 module? If not, you can get one for about $20 to check for codes etc.
Thanks! Yes it’s happened about 4 times in the last 3 months..We checked with a reader and nothing came up. I am planning to get a load test done on the alt in case that was the problem and it may very well be. At present it seems to have rebooted itself as I disconnected the battery and reconnected..
Did you ever find the culprit? My 2015 is doing the same thing and also the battery is only a few months old. We have disconnected the battery but didn’t get the same result as you. It’s still happening. Thanks!
