On my 13 Honda pilot awd, if parked overnight or sitting still for extended period of time and I turn wheels I hear and feel a pop from front right of vehicle. And again only hear when I'm not moving. I've replaced inner and outer tie rod ends, stabilizer links and bushings. I replaced struts and mount/bearing 30k miles/1 year ago. Someone said might be cv axle, cv axle on right does show signs of leaking. Any help would be greatly appreciated.
Sounds like a CV Joint, especially if it’s leaking grease. Try turning the vehicle in a circle a few times to see if you can get the vehicle to make the same noise.
Why would you want to turn the wheels when the vehicle isn’t moving? It seems that would place a fair amount of strain on the steering related components unless you’re on a low traction surface.
