Sorry about the radio silence of late.
I've been happy with the lift kit. Except the rear being only 1". I bought rubber spacers to hopefully get another inch out of the rear but never got around to actually installing them.
Just to try to clear things up. All the part numbers between suspension parts from 09-13 were the same so I could not see where there was any difference that would cut off the 12-15 pilots from using this kit. My guess would be that Readylift designed this kit in 2011 and never revised it to reflect the 12-15 Pilots.
Every part fit and works as expected. Except for the adjustable rear control arms. I did some research on that and found that the ball joint end that was supplied was actually for an Odyssey. So I ordered the correct ends for the Pilot. Almost worked. When installed, the adjusters are maxed out when set to factory length. So the adjusting nut was too short and the wrong ends were supplied to begin with. So I ordered the longer adjusting nuts. Meanwhile, I completed the install and took it to get aligned. Everything still came within spec so I never even installed the adjustable arms that took so much time to figure out. I guess when I get around to adding another inch to rear I might need to use them. Or I will find out why Readylift could only design it for 1" lift!
Lift was installed around 40k miles. We are pushing 75k miles now. There have been no problems at all. Ride quality is good. Tire wear is even.
I experimented with deleting the anti-sway bars. It definitely rode better off road, but it's mostly used on road so the bars were left on.
