I'm interested to see the responses on this also, I just purchased my Pilot and now looking at trailers.
I pull a 23 ft Airstream Serenity with a GVWR of 6000 pounds. The dry weight is 4600 and I am likely carrying 800 pounds of water, propane, food amd clothing. The unit has tandem axles, a Hensley hitch and a Prodigy electronic brake controller. My friend pulls a 25 ft airstream which is 1000 pounds heavier than mine with a 2006 Ridgeline. It handles it well.I have a 2012 4WD Pilot and I was wondering what kinds of RV travel trailers all of you out there are pulling with your own 2012 4WD Pilots.
Let us all know your own specific trailer details, like:
Also, please let us know if you would recommend a lighter GVWR than your own, or if you think the Pilot 4WD could handle one a bit heavier.
- Brand
- Model
- Length
- GVWR
- 1 or 2 axles
- Stock hitch or load-distributing
- Electronic brake controller
Thank you! :29:
You gotta post pics of that set up!!!I pull a 23 ft Airstream Serenity with a GVWR of 6000 pounds. The dry weight is 4600 and I am likely carrying 800 pounds of water, propane, food amd clothing. The unit has tandem axles, a Hensley hitch and a Prodigy electronic brake controller. My friend pulls a 25 ft airstream which is 1000 pounds heavier than mine with a 2006 Ridgeline. It handles it well.
Uh no, I wish the highways and interstates I travel were level! But I havent done grades over 6%, like down too the Mississippi river or Mountains. But I do plan to now that I'm so impressed with the Pilot.I dont see how some of you guys are towing trailers weighing more than 4000 lbs? Are you towing only on flat ground?
With all due respect, some of the replies here are borderline delusional. Weight is precisely everything - a fact some of you will learn the first time traffic on the Interstate inexplicably and suddenly comes to a full and complete stop directly in front of you with no warning and that trailer decides it's going to either pull out and pass you, or that it wants to drive a while and starts pushing you down the road - with the trailer brakes locked and screaming.Weight isnt everything when it comes to travel trailers.
You must think some of us are rookies. Think again.With all due respect, some of the replies here are borderline delusional. Weight is precisely everything - a fact some of you will learn the first time traffic on the Interstate inexplicably and suddenly comes to a full and complete stop directly in front of you with no warning and that trailer decides it's going to either pull out and pass you, or that it wants to drive a while and starts pushing you down the road - with the trailer brakes locked and screaming.
i don't carry a full tank (39 gal ) unless i know i won't have access to water at my destination. I do like to have some good water in my tank for drinking/coffee, etc. Bear in mind that the shape of an airstream reduces wind resistance significanly. No trouble maintaing 60 mph on highway hills.you gotta post pics of that set up!!!
You carry a full tank of water too? Holy crap.
Wow...cant find a bit of humor in my race comment I see. The point I was making is that I can accelerate quicker and brake in much less distance than your rig any day, any time.Rincon:
I normally don't respond to juvenile posts such as "Want to race up hill on an Interstate exit to exit and come to a complete stop? Cause I'll bet big money I'll beat that massive rig you got, and I'll stop a lot faster too!", but yours deserves making an exception.
Since when are "balls" (read: masculinity) determined by how hard you can mash a brake pedal? You clearly have led a sheltered life if your claim to fame is that you have slammed on your trailer brakes and lived to tell about it. "There I was, surrounded by hostile Chevy drivers, but by God I showed "em! I locked that baby up after racing up an on ramp!" WOW indeed.
Basic math seems to escape you as well since you don't understand that I have over 1.5X times the tire surface on the pavement that you do (six larger tires as opposed to 4 smaller ones). What does the extra rubber buy me? How about stability when an 18 wheeler passes me? And by your own assertion, since weight doesn't matter, then the extra weight I'm hauling is clearly offset by the extra tires.
And no I can't quote you the exact weight of my rig. With a 36 gallon diesel tank, it will vary depending on fuel load, and the trailer will vary based on what we happen to be taking along on this trip. But not being near my truck's ability to pull means I have the luxury of a fudge factor of 500 pounds or more, no problem.
"You must think some of us are rookies. Think again." Let's be clear here. No one has appointed you as the official spokesman for "some of us", I'm speaking strictly to you. If you truly don't understand the difference between the safety and stability of a 16K rated 5th wheel hitch located directly over the rear axle (and 4 tires) of the towing vehicle versus something mounted to a "come along" hitch located completely behind the towing vehicle, then "rookie" would be a compliment. In fact "obtuse" would seem to be a better fit, or "obtuse, but with balls" just to be fair in your case.
Look, I actually know that I'm comparing apples to oranges here, OK? Why that's personally offensive to you escapes me, but learn to live with it.
