Was driving my wife's 2012 pilot home from work cruising at 60mph when the vehicle suddenly started shuddering, i pulled over and shut it off.
The check engine light is flashing, VTM-4 light on, and it displays "check emissions sys" and "check vsa sys". Showing p0303 code when an obd scanner is plugged in. What could cause this? Thanks in advance.
P0303 is cylinder misfire.
How many miles does the car have on it?
Have you replaced the timing belt? If so when and what parts were used?
Have you changed your spark plugs? Valve adjustment?
Need more information.
i had the same problem with mine ...it was fixed at the dealer for a few dollars
