2012 EXL Stereo Build
91K views 73 replies 21 participants last post by  Gcortezc1
#1 · (Edited by Moderator)
This may sound extreme to some people, but I spend a lot of time behind the wheel. I have been known to drive 900 miles a day and listening to music just breaks up time.
The original plan was to keep the stock head unit (the cheap non-Navigational head unit) and just build on from there, so I installed the following:
Morel Hybrid 6 inch component speaker (fronts)
Morel Tempo 6" coax with external crossover (rear fill)
Audio Control LCQ-1 6 channel EQ factory interface module with accubass
Audio Control Matrix Plus 6-channel line driver
JL Audio HD 900/5 5 channel amplifier
JL Audio TW5 thin woofer
Basic Layout: The Morel drivers where mounted in the stock speakers locations. The JL Amp and Sub were mounted in the cubby/ headrest storage area. The JL Flat Sub is in a sealed box (just a bit smaller than JL recommends and yes it can pound out the bass).
After the installation and many hours tweaking the system overall sound was great except for two items.
FIRST: while the head unit was warming up/communicating with the rest of the Pilot you could hear and electronic noise through the newly installed drivers. After a few seconds of this noise it would clear up and sound good. This could have been overcome by a simple toggle switch, turning off the amp until the radio was up and running. I tried a delay turn on, but this would not delay the amp long enough so that idea was ditched. Auto Control also confirmed that the problem was with the Honda head unit and doubted that using a Clear Sweep would be any better.
SECOND: The stock head unit produced a “floor noise” that I could hear, the average person would say wow what a system. But I have had some fairly high end systems in the past I wanted that high end sound in the Pilot. This could not be overcome (I was asking just too much of the stock head unit).
My answer was to ditch the stock head unit in favor of a Kenwood KDC-X996 In-Dash CD Receiver and the Audio Control L QC. This unit has the navigation, time alignment and EQ settings to fine tune the system. The only problem was where to put it? The logical spot was where the stock unit is, so the disassembly started with a new custom made center dash. I hope to have this finished this weekend and will post pictures when done.
See less See more
#3 · (Edited)
Sub & Amp Rack
#4 · (Edited)
Not to knock you, but kudos on the build. Why use the lcq and matrix? have you considered grounding all units including head to same spot? also where are you getting your remote from? I'll be putting in an alpine amp with built in hi level input and report if I have the same noise.
#5 · (Edited)
I used the LCQ as a "gateway" from stock speakers and this converts it to RCA's that plung in to the amp.
The Matrix Plus kicks the voltage up going to the amp an being able to turn the amp gains down (the voltage of the stock head unit is very low).
Since up grading to the Kenwood head unit I have removed the Auto Control LQC, I plan on keeping the Matrix Plus even thought the Kenwoods out put voltage is 5voilts. The matrix will boost that voltage up to around 9volts.
I have tried all different grounds with no positive effect. When Audio Control confirmed that the problem is not the install..... but the Honda radio, that is when I started looking for different options.
#7 ·
To be honest I am still re-working the dash for the new Kenwood. Trust me this is not a ground issue. It is a signal that is going through the system, when you first turn on the stock radio and you see the "H" on the display, that is when most of the noise is at it's highest. I have had Auto Control and several other people go over the install (including one person that trains installers).
Most people would be very happy with the system I am replacing.... but there is always one person like me that is very picky or maybe just a pain in the A$$.
#9 ·
The sub was never touched..... but it was disconected from the system. I have mid-bass drivers in my Chevy kick pannels large than the Honda Sub.
#10 ·
Where are you tapping the power for the new headunit and interface boxes? If you're using harness power have you tried to power it from the AMP power line (I assume you have a direct battery wire to run your JL Audio)
Sometime just relocating cables away from the noise source helps. Is the noise generated in the headunit or a interconnect cable or box?
#11 ·
The power for the Kenwood is not using any exsisting factory wires, all new power wires are seperate from the factory wires. Just like the speaker wires are new running from the amp to the speakers.
This is a complete re-work. The only thing that is or maybe used is the back-up camera.
#13 · (Edited)
May I ask what are you going to do? Remove the stock display or just and on to the stock head unit?
Do not forget the pictures... or it didn't happen :)
#15 ·
DMG,
How did replacing the HU affect the Bluetooth, rear camera and other display functions? Not sure what is controlled by the HU but do you lose everything? That would be a deal breaker for me. Were you able to interface the steering wheel controls with the new HU? How are you finding the noise when the engine drops to 4 or 3 cylinders with no ANC? Sorry for all the questions but I too am unhappy with the stock system in my EX-L. I was almost wishing I had sprung for the Touring because I am upgrading the stereo, adding roof rack and towing harness but I've read on another thread how unhappy many are with the Touring stereo as well. I just ordered an Alpine KTP-445U 45W RMS x 4 amp. It has speaker level inputs so that will eliminate the level converter and I already have a Rockford 500W monoblock amp to power my 12" sub. All I've done so far is run a power cable from the battery to under the seats but I'm hoping to get it all installed next weekend. I miss the system I had in my old Pilot!
#16 ·
[FONT=&quot]Hey Toolman, the Kenwood has the BT and the back-up camera input built in to the head-unit (it’s a double din head-unit). I used a PAC SWI-RC unit to interface with the steering wheel controls and the Kenwood. I mounted the Kenwood BT mic. in the stock location in the overhead consul. When I have some more time I plan on installing the stock display in a motorized piece mounted in the center consul. On my first try using the stock head-unit I had no noise when the Pilot dropped cylinders, only when starting the car did I have excessive noise except for a very high “floor noise” (in my opinion). Most of the noise I experienced was when the radio turned on, when you see the big “H” on the display.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]So far I have only tested out the system (no RTA or fine tuning yet) and I am very happy with it. I did run into a small problem with the texture and color matching of the new center dash, so this set me back a few days. For me I am not sure if I would be happy with the Touring system, so I would still have to do some up-grading of the sound system. The up-side of the touring is it has an Alpine head-unit that can use the Auto Control LQC without the noise I experienced (not sure if the floor noise is better).[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]When I had the ANC hooked-up it tried to adjust the system that I was trying to tune, it was like “trying to herd a bunch of cats and never winning.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]One of the things I want to re-do is the rear floor where the sub is, I want to get some carpet without backing so you cannot see where the sub is.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]I should finish up the install in the next few days (fingers are crossed after saying that) & will post some pictures when done.[/FONT]
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Title"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} </style> <![endif]-->
#17 ·
I look forward to the pics. I'll let you know how my installation goes as well. I considered installing a relay to turn on ANC mics when audio system is off and short them when audio system is on but I have a feeling just adding and amp will make that impossible. Your system sounds really nice. The guys who got the Navi (Alpine HU) aren't complaining of high noise floor. I love my Pilot but not happy with Honda for the things they've cheapened in it, especially the stereo...
BTW, any tips on getting the door panels off?
Good Luck and take care,
Joe
#22 ·
Thank you! I am very impressed with the system as a whole, especially when you consider I am only using 1 sub and just 1 amp to power the system. I.M.O. I think it sounds good enough to place quite well in a IASCA SQ competition, but that's just me ;)
#24 ·
Hi Joe, I am not sure how the "relay or the pot" idea would work. I know most people have problems with the ANC & Sub, but I think the the ANC goes through all the speakers.
I am away from the house untill Weds. when I get back I could look up what mic is for the BT and what one is the darn ANC. :29:
#25 ·
The relays would be powered from the power antenna output of the HU. When the HU is powered on, it would activate the relays (one for the front mic and one for the rear), which would switch them off, deactivating the ANC.
The pot would just decrease the gain of the mic in an attempt to make the ANC work with the external sub. My understanding of how the ANC works is that the mic picks up low frequency noise of the engine and outputs a signal (presumably from the sub) that is 180 degrees out of phase and of equal amplitude to the offending noise to cancel it. My theory is that when you add an external sub, that cancellation signal is too loud so rather than cancel it it actually recreates the noise it is trying to cancel but just 180 degrees out of phase. The noise I could hear coming out of the sub sounded like the vibration of the engine in eco mode but much, much louder. My thought was if I could decrease the gain of the mic, I might be able to bring the cancellation signal back to the level it should be. As I think it through though, I'd probably have to use the factory sub as it position relative to the car affects the phase. Either that or a sub amp with variable phase would be required. The more I think about it, the more I think it would be like herding cats as you said before. I'm sure a lot of engineering went into the ANC system and merely dropping the gain of the mic won't fix it but the relay to switch them off would work. I would just have to run a wire to the front and rear ANC mics to power the relays and I have to find 2 relays small enough to fit in the headliner.
I did some searching and found a post in another group instructing that you have to take apart the front mic assembly and cut the red wire going from the mic to the PCB inside the mic housing. Let me know if that sounds about right when you get back and thanks for the help.
-Joe
#26 · (Edited)
Who left the gate open and let all the cats out?
OOPS I just re-read your post on using the power ant. good idea (my ant. is the the read side widow) cell phone screens are too small for me to read a post!
I think your idea of the relay would be the best. The problem is there is no remote turn on wire coming out of the stock head-unit to power the relays. You might think about using a simple toggle switch to turn off the mics or better yet just do not use them (I do not notice a big difference with or without the ANC). You might want to disconnect the mics and see if the extra noise disturbs your serenity or causes you any of the fallowing; road-rage, reddening of the eyes, stomach craps, pregnancy or anal leakage. :p
<O:p</O:pI do not think the shop manual shows the wiring inside the mic, only how to trouble shoot it to see if it works or not, but it does show the wiring to and from the mics.
#27 ·
Same antenna here but that window antenna has a preamp, which I believe is powered from the HU. I know when I upgraded the HU in my 2004 Pilot, I was wondering for days why my new Alpine HU would only pick up 3 stations and then after some research, I learned that antenna is powered. Hooked it up and voila, I had reception! The antenna jack in the stock HU of my 2012 EXL has 2 cables. I'm hoping one is power but I'll poke around all the cables in the back of the HU with my meter to see if one only has power with the HU on. Right now, I have my subwoofer amp turn on line connected to the cigarette lighter jack so it powers on when the car is turned on but I'd rather have that power on with the audio system as well.
As far as the front mic goes, I'd rather not have to take it apart and just clip a wire. I just have no way of figuring it out rather than trial and error because I think you must be driving for the ANC to activate.
-Joe
<o:p</oI do not think the shop manual shows the wiring inside the mic, only how to trouble shoot it to see if it works or not, but it does show the wiring to and from the mics.
#29 ·
I thought I would up-date my post with some pictures during the install. I also have re-do the cargo cover hiding the amp and sub.
#31 · (Edited)
Cargo cover 2012 Pilot
My cargo cover wouldn't clear my sub and I didn't like the space between the seatback and the cover. What was Honda thinking with a 2" gap at the front of the cargo cover that you can see in???
At any rate, I cut 2 square holes in my rear pillars, which allowed me to move my cargo cover forward and up a few inches. This eliminated the gap and allowed the cover to clear my sub. The cargo cover is a crappy design in my opinion. The one in my 2004 was much better. The one in my wife's CR-V is also much better.
Joe
#32 ·
Hi Joe,
That cargo cover is a very light weight "honey-cone" that would rattle when the sub would hit hard. I tried velcro to hold it in place but it still ratted, so I made a new one out of MDF and rounded the outside edges & recessed were the metal grill mounts to it and no more rattles.
Were are your pictures.... I want to see yours
#34 ·
Cool I look forward to seeing your pictures, I like to see what others have done.
The main reason for re-doing the hatch-cargo cover; is the rattles and when I cut the hole for the sub instead of being round it came out like an oval. :rolleyes:
#36 ·
The power wires are run down the passenger side and the speaker wires are down the drivers side.
I just wish I had a better camera during the install! A cell phone is a phone - sometimes but it's never a camera.
#37 ·
Install photos
Here are some pics. Unfortunately, I didn't take pics of where the main amp is installed or the wiring to it. I installed a power block under the driver's seat. I have #4 from the battery through 100A breaker. Enters through existing grommet in firewall then runs down front pillar and driver's side threshold to power block under seat. I have the #4 going in and it has 4x #6 out. One goes to main amp, one to sub amp, one to Ham radio and I have a spare for future gadgetry. Sub speaker wire out of stock HU through center console to level converter and to sub amp. Stock sub left connected in case I need to remove sub box for Home Depot runs.
Joe
#38 ·
Looks like a good clean install and I do like having a knob to control the sub. How did you mount the Ham antenna? Did you have to drill any holes in the roof?
#39 · (Edited)
No holes. I removed the end cap from the left roof rail and slid the heads of 2 ¼-20 carriage bolts into the rail channel so the threaded end was sticking out of the center of the rail. Then I bolted a bracket that I modified to the inside of the rail using the carriage bolts and ¼" nuts, washers and lock washers. I used all stainless hardware. I had to cut the plastic molding that is by the liftgate hinge to pass the cables through then I ran the cables in through the slot where the power arm for the power liftgate comes out. I bought a spare plastic molding for when the day comes that I sell the vehicle. By then, it may not be available anymore and that will allow me to put it back the way it was when I remove the cables. See photo.
I'm still waiting for a connector to mount the antenna to the bracket. Once that arrives (maybe today?) I'll mount the antenna and take a video of the motorized mount. It's pretty cool.
#40 ·
i just realized that since i have a 11 lx, my a/c display is up top where the radio display is, so placing a double din up there is out of the question, might just have to invest in a Rosen unit instead.
