Hi All - So is there any scenario that would make over 5 quarts drain out when parked on level ground? I'm guessing it was just way overfilled? I would appreciate any thoughts.
I put 3.6 quarts back in, per manual. Sitting cold it was at the low mark on the dipstick.
I recently did my 2015 tranny d&f.
I don't measure what comes out, goes in my oil pain and to the recycle bin. But, I put about 3.5 back in, started it, temp gauge up to 1/3, ran it thru some gears with the brake on.
Checked and it did not register on the dipstick! I almost panicked, put the remainder- so 4 qts in. then it barley hit the low mark after running it some.
Go figure
Reactions: sidefly
Premium Member
The transmission holds more than the typical drain inside the torque converter.
I suppose if we let it drain long enough more than normal would come out...
Reactions: sidefly
Thanks for the replies! I did let it drain until it stopped dripping, I wasn't paying attention since I was doing the rear diff at the same time. It was a while... So I did the shift through the gears thing and <CRAP> it wasn't showing on the dipstick. I even waited until the fan ran. So, I added my leftover making it a full 4. Still it was between the marks, so I had a half full old bottle of it and dumped that in to. Now it shows just over the full hole. So much for the manual.
Thanks again!!
I've observed on our 6AT G2 Ridgeline doing a cold drain with the drivers side elevated a little using a floor jack, that it will quickly dump 1 gallon (measured on the drain pan) and then starts a very slow drip. Dripping 5 minutes or 30 minutes makes very little difference. Kinda like the motor oil......quick dump, slow drip.
I've presumed the factory fill was correct so the 1st time I pulled the tranny dipstick (cold, sitting overnight) the fluid level was +/-3/16" above the top mark. Refilling with 1 gallon TF gives me the same result. Checking hot tranny fluid 60-90 after driving around gets interesting......the EGR tube, radiator hoses and back side of the efan get really toasty. Glove/long sleeve helps.:eek: Checking hot right after driving gave a fluid level right at the "T" in HOT. Think I'll stick with checking fluid level on a cold tranny.👌
Cant see the COLD level, buts it's above the top mark.
