Hello all,
i have owned my 2011 Honda Pilot touring for a couple months now, loving and hating it at the same time. I’ve seen some post on here and totally agree with the same common headaches.
Well last night driving home from work, on the highway when accelerating,VTM-4, VSA, and check engine light all came on. Car started jerking and skipping. I pulled over and when I stopped the cars engine shut off. I wasn’t aware until I tried pressing the gas and nothing happened, but the car moving slightly backwards since I wasn’t applying the breaks. Car started up right away when I turned the key with all lights still on the dash. The next morning I took it to the local mechanic shop, he ran the OBD codes which showed:
P0100
P0300
P0301
P0302
P0305
P0306
Things that have been changed on car before this misfire happened was the MAF sensor and spark plugs (both from factory original) due to what I thought was a transmission problem because the car would jerk when trying to switch to next gear. Didn’t matter if it was second or 4rth gear. I’m also dealing with that ECO mode shutter switching on and off with slight vibrations.
Does anyone know what would be causing these misfires to happen? I’m thinking clogged cat but I’m no mechanic. And I’m still stuck on believing something is wrong with either the transmission or throttle body/differential.
Any advice will be highly appreciated because I’m hoping the car lasts me 5 more years.
Mileage on vehicle is currently 136,258. No warranty.
P0100
P0300
P0301
P0302
P0305
P0306
