My 2011 Pilot, electric system light came on yesterday. on the way to the shop, all the dash lights flashed and then it shut off. will not turn back on. Please help! Is this going to cost a fortune?
The alternator would be my first assumption as well. I’ve had a couple of vehicles do the same thing while I drove. All the dash lights flicker on and then the car just dies. You’d have to charge your battery, throw a new battery in or have it towed to your nearest mechanic. Alternator is no longer charging your battery in that case.
Alternator failed, Pilot driven long enough for battery to go flat. Then poof... it's doa.
Check your spool valve to see if it was leaking on your alternator, which killed it.
