1 - 2 of 2 Posts
Please help, the cooling sensors are good relays are good AC compressor is fully charged what else controls the fan circuit ?
If your fans don't come on when you turn your a/c on and you are for certain fuses and relays and temperature sensor are good and all your wiring harnesses are tested, getting power and undamaged, then your fans likely need replacing. You can hot wire these to test them.
1 - 2 of 2 Posts
