2011 pilot with 66k. Lost all power while driving. Dealer said it was a bad battery cable and replaced it. Next morning, battery is dead. Replaced battery, started right up. Next morning new battery dead. Jump start car, 5 minutes later there is an arcing noise and a puff of smoke from engine. Shut car off immediately. Alternator tested good. Any ideas of what this could be?
A/C compressor relay. Common issue.
Sent from my SM-N950U using Tapatalk
Battery cable harness only connects to the positive side of the battery. Check ground/chassis/battery negative wires, especially any on the lower side of the engine block. Look for corrosion, bad connections, etc.
Discussion Starter #6
Took it to a local mechanic... found a loose connection at one of the main fuse terminals... like someone forgot to tighten one of them down all they way.
