1 - 2 of 2 Posts
I got a 2011 Honda Pilot ex with the check engine light, triangle, vsa, vtm-4 what’s the fix?? The lights will go away and Then while later it comes back. It comes and goes p0303. 3rd cylinder. Does the rings need replace.
Hello Tony,
Sorry we missed your question.
VSA light can come on due to tire quality and driving conditions. Have you lost any traction?
As far as your misfire code, I'd in no way go straight to thinking ring replacement. Have you done the basics? #1 being to disable the VCM. Here's my to do list...
  • Disable VCM
  • Air Filter New/Clean
  • Clean MAF
  • Air intake hose is leak free
  • OEM Spark plugs new/clean
  • Spark plug tubes dry oil free
  • Disable the VCM
  • Coils firing
  • PCV valve changed/new
  • EGR valve new/clean if 180k+
  • Use Full synthetic oil
  • Use Top Tier 87 octane fuel or injector Cleaner
  • Disable the VCM
Hope this helps.
Reactions: aggrex
1 - 2 of 2 Posts
