1 - 2 of 2 Posts
I have a 2011 Honda Pilot and it makes the center console cranking noise …. Yet I figured out how to fix …. Once it makes the noise …. Just raise the driver temperature all the way to HI (HOT) and then noise goes away …. Then after noise goes away lower the driver side temperature control back to Lo (Cold) …. Noise is gone !
Common issue where one of the HVAC motor controls starts to go bad. Most likely the grease has dried and preventing the mechanical arms from moving....therefor you hear the "cranking noise". Some describe the noise as a small animal climbing around.
1 - 2 of 2 Posts
