Hi all, 2010 Pilot ex-l . I start off with driving the car no issues until after about 40mi of driving, engine jolts and then after a few seconds engine quits with the abs, vsa and check engine light popping up. Few codes 83-01, 65-01, 61-01, P2101 and P2176 that I picked up. Anyone with similar issues and solutions?
Where's my popcorn? I'm NOT being sarcastic.
We had this happen similar to our 08 FWD Pilot.
IIRC- it was the VCM selenoid?
The popcorn b/c I want to see others responses.
Hang on a bit- some smart folks up in here.
I'd look at these first.
148142
148144
Any work been performed on the throttle body recently?
I'd inspect the Air Filter, Air Filter box, Air intake hose for leaks. Clean the MAF, And clean the throttle body front and back if it appears to be dirty and all the wiring harnesses check out to be ok. Hopefully not a rat attack on wiring.
Thanks folks. Quick update. Cleaned up the throttle valve body and Pilot has been running smooth.
Breilliant! And you didn't even throw thousands of dollars at it, change the plugs and coil packs? LOL
Reactions: Nail Grease
Nice!
Another success story without going to the service dept! 😁👍
