1 - 1 of 1 Posts
Hello,
I did research this on the archives but did not find anything that mirrored my problem.
Started up the Pilot yesterday and bingo! The AWD (VTS-4) Stability (VSA), Tire pressure warning and ABS all lit up and stayed on. My OBD reader did not show any fault codes. Took it to Advance Auto, they have a not so great reader but better than mine but it did not pull any anything either.
I am guessing there is a bad fuse/wire component or wheel sensor that has gone belly up. However, if this is the case I am at a loss to determine which wheel/circuit. I've yet to find an accurate diagram or schematic of which fuses in a Pilot correspond to which circuits.
Can anyone provide some advice or help? I can't be the first guy this has happened to.
Thanks if you can, Darwin
1 - 1 of 1 Posts
