1 - 2 of 2 Posts
2009 honda pilot touring 138,000miles
Recently my 2009 pilots tailgate malfunctioned, I pressed the key remote for the tailgate to open and it went halfway and returned to close I pressed the button on the hatch also the one located the driver door, checked all fuses and relays all good the dash reads please check tailgate tried resetting by taking off battery terminal same issue please help before I make an appointment for the dealer
Will it open manually when you use the button on the hatch handle? If not, you may be stuck for some reason. There is a procedure for opening the hatch manually described in the owners manual. I'm not familiar with the 2009 so don't know exactly where that manual release is.
Also double check to make sure the glass hatch is fully latched. That will keep the hatch from working.
Here is the manual opening instructions.
137476
1 - 2 of 2 Posts
