I have a 09 Pilot EX with 231K miles on it and have been going through the investigation for the P0507 high idle code. The usual sustpects have been addressed including a new throttle body installed.
next step would be to check and replace the power steering pressure switch . I have looked online and cannot seem to locate something that makes it clear to me where it is located , hate to replace wrong switch.
can anyone assist?
Matt
2019 Honda Pilot Touring AWD
Did you check your intake tube for any tears? I’d suspect and vacuum leak somewhere.
Hi
I went over the motor and I actually had it to my local mechanic who did all the same tests, adding to it the smoke test of vacuum system. No leak was found , unfortunately.
I had a radiator failure in the coolant line for the transmission fluid that blew out and went all over that area of the motor . The switch is cheap and possible cause so I am trolling for an answer at this point.
