1 - 2 of 2 Posts
my 2009 honda pilot touring/navigation camera went fuzzy and then went dead. I assume it is shorted out by water or rust.
per honda, I need a 39530-SZA-A01 for my navigation
$350-$400 new at honda.
I found a 39530-SZA-A11 at the recycle yard
honda web site says this is a 2009-2011 EXL (leather)
but it may only support the rear view mirror?,
will it work ?
does anyone have a A01 for sale?
I may need to sell this A11?
Discussion Starter · #2 ·
did some research
39350-sza-a01 is for 2009-2011 touring/navigation or some 2012-2015 EX-L
39350-sza-a11 is for 2009-2011 EX-L with rear view mirror - blue screen is camera is bad
39350-sza-a21 is for 2012-2015 touring or EX-L with navigation (aka "wide") - 4x2=8 pin white plug
the *********** plugs are all different
honda list price is $400+ some dealers sell cameras for $315+ship
to remove your old camera:
1) REMOVE PLASTIC TRUNK TRIM:
remove the pull cord/screw
pry off the bottom handle off and unhook electric
MUST open the hatch glass
gentle pry off the hatch plastic rim off - using a plastic tool to avoid scratching/breaking the clips
  • first remove on the top curved piece by the hatch glass
  • then do the bottom hatch section note: it may take some "pulling" to get this panel off
2) REMOVE CHROME BEZEL:
from inside trunk, unplug the 2 wires
the grey plug is the license plate lights and the white plug is the camera
then try the new camera out by plugging into the white plug -- car in reverse, of course
if camera works ok,
remove the 2 nuts on the ends of the chrome piece
push the 2 white clips out from the inside to avoid breaking them
-- if you do,order 91512-SJK-003 form hondal like four dollars each
3) remove the chrome piece
4) REMOVE WIRE HARNESS:
carefully remove the 4 larger screws : 2 by camera and 2 by the glass lock
remove the harness - unclick the 2 license plate lamps and unclick the glass lock clip
CHECK the camera model number on back
replace the harness with the new camera harness
5) REINSTALL IN REVERSE ORDER
NOTE: I would also replace the 2 license plate lamps while you have the chrome piece off - much easier
sylvania 2825 around six dollars for 2
with a small tool - pry the 2 white plastic lids off and replace the 2 bulbs
1 - 2 of 2 Posts
