1 - 1 of 1 Posts
My passenger door handle has decided not to work. I can open the door from the inside handle. On visual inspection, I cannot see what is causing the problem. When this happened, the door handle seemed stuck, I pulled harder and it moved, but the door did not open. The handle will stay in the open position until I hit it hard to push it back in. Is there something that can be fixed with this handle or do I need to replace the handle?
Any suggestions on where to get the part, if needed. I have found Youtube videos for taking off the inside of the door, but not replacing the handle (at least not for the passenger door or 2009-2011 models, only for the older model).
1 - 1 of 1 Posts
