Last week, I bought a 2008 EX-L navi Pilot with 114,000 miles. What a nice SUV.
I need to replace the turn signal relay. Where is it located?
There's a 7.5A turn signal fuse located in position no. 10 of the interior fuse box, driver's side.
I recall someone mentioning the relay is on the back side of the fuse box which contains the turn signal fuse. Unfortunately I don’t remember if that was on the Pilot forum or another forum that I subscribe to.
Reactions: skifast
OK, this should help:
The turn signal relay is on the back side of the driver's side fuse box in the kick panel area. From the front, it's behind the upper-right corner. To access it, you'll have to remove a 10mm nut and then the whole fuse box will slide out. You may have to disconnect some harnesses to turn the fuse box around. Be careful....if you have to disconnect any of the SRS harnesses (clearly marked with yellow), disconnect the negative terminal of your battery first and then wait 3 minutes.
https://www.piloteers.org/threads/turn-signal-hazard-problem-relay.28556/#post-372782
https://www.piloteers.org/threads/turn-signal-flasher.13424/#post-210553
