1 - 2 of 2 Posts
Greetings i have a to replace all my coil packs on engine. I am getting a misfire on cylinder 1-6 any recommendations? Also have my Vtec oil pressure switch out p2647. Need to get valve cover switched its leaking oil and recommendations. my car has 225 miles need a little TLC i dont want to let it go
Have you tested each coil pack to say that?
If your replacing the oil switch, replace the whole (VVT) Variable Valve Timing Solinoidnwith gaskets and screens. This could be affecting timing and causing misfire codes. Do you have an AWD or 2wd? 2wd has another set of these on the back driver side head.
Have you replaced the MAP? These can cause trouble with the fuel air mixture. Inspect your plastic air intake hose for cracks.
Reactions: aggrex
1 - 2 of 2 Posts
