1 - 2 of 2 Posts
Hello all
Vehicle is a 2008 Honda Pilot 4WD SE J35A9 engine.
The engine is making a rotating ticking noise which is sometimes quite pronounced.
Most apparent starting a low speed roll in lower gears.
Here is a short history of related repairs (not all seeking to remedy engine noise but all related)
12JUN2020 Serpentine belt tensioner replaced - 171K
12JUN2019 Timing belt, water pump, tensioner, drive belt, and coolant replaced - 157K
14JUN2018 A/C compressor, hub, and coil replaced (not cooling) - 133K
14JUN2018 Tensioner replaced (goodwill warranty) - 133K
21SEP2017 Serpentine belt and tensioner replaced - 119K
2015JUN06 Serpentine belt and tensioner replaced - 78K
10OCT2014 Timing belt, camshaft oil seal, camshaft sprocket, crankshaft oil seal, crankshaft sprocket,
timing belt tensioner, head, and other parts/subassemblies replaced
(cracked head - plug blew out) - 69K
Here is a link to a video for review.
Rocking is me holding the camera, not the engine.
Please provide any wise/sage advice.
Thanks in advance
Andrew R.
Berryville VA
1 - 2 of 2 Posts
