Honda recommends an ATF change (drain and refill only, no flushing) every 30K miles.
If it looks brown, it should probably be changed. Normal color is red.
Honda recommends using only their ATF (currently DW-1 formula).
Some have reported using Valvoline MaxLife DEX/MERC ATF without any adverse issues.
One cycle of drain/refill only changes about 1/3 of the total fluid, so a "complete" change requires four drain/refill cycles, with some driving in between each cycle. Periodic maintenance specifies just one drain/refill cycle. See how the fluid looks and the car drives after that.
If your Pilot is AWD/4WD, then the front transfer case and rear differential fluids are due for a change now, too.
The front transfer case uses 80W-90 gear oil. 75W-90 supposedly works fine, as well.
Valvoline and others have a suitable product.
The rear differential takes only Honda's specific VTM-4 fluid.
The timing belt is typically due for replacement at 105K miles or after 7 years.
Has it been replaced, yet, on your car?
If you don't have an owners manual, download a copy here: Owner's Manual | 2007 Honda Pilot | Honda Owners Site
Familiarize yourself with the operation of the maintenance minder.
