Not that it matters per se, but why within each set of coil ignition wires is one wire a different color ?
Each set of 3 wires has a black with white stripe on the outside position, a black wire in the middle position (this is the same on all sets of the 6 coil wire sets), and a colored wire on the other outside position.
Is this just to be able to identify the coil a particular wire set is going to ?
I just took these connectors off a wreck at the bone yard.
Does anyone have a copy of the ignition wires diagram for a 2007 EXL 4 WD 3.5 VTEC that they could send me or post here ?
Thx so much.
141608
THANK YOU SO MUCH :)
Upon a very close inspection of the connector, I can see 3 distinct markings on the side opposite the tab - first looks like a +, then definitely a P, and finally what appears to be a 3 (but could be a 5 or an s - but I think it is a 3). I wonder what these marking are ???
