1 - 2 of 2 Posts
I have a 1.26-1.30 amp draw on my battery after shutting off the car and locking the doors. If i pull out the 15amp ACG S fuse, it drops to .50 amp. it will remain the same until the car is started again. Any ideas?
Your alternator shorted from the sound of it. And something else too. Do you have an aftermarket alarm? They are notorious for drains.
How many miles on the alternator? If around 70k and it is OEM then it is up for replacdement. If way less than that then check the diagrams to see where else the drain could be.
1 - 2 of 2 Posts
