Drips coming from AC compressor area may be the oil pump seepage. Outside of the PCV valve and valve cover gasket, I can't think of anything else above that area that could leak oil.
If you had more leaks dropping from the rear on that side, in the area of the oil filter housing, I'd say it was the gasket for that solenoid.
But when I had seepage/leakage on mine, pretty much that whole side had a nice coating of oil on it, but no drip marks in the driveway.
Had I known what I know now, the second TB change at 200k I would have resealed the oil pump while I was at it, knowing I was going to attempt to keep the vehicle for 300k-400k.
Either way, as you can see, you do need to hose down all areas with degreaser, lightly spray off, then see if you can find out exactly where that oil is coming from.
On mine, I was worried the leaking oil pump would contaminate the TB, but found that it was leaking from the engine side of the oil pump, and the lower TB cover has a rubber gasket on it that was keeping it from getting into the TB area. Resealed the oil pump and replaced the crank seal, which was easy enough to remove once the oil pump was off the car. I didn't touch the cam seals, as they were fine, but have them if they are leaking in a couple years when I get to do the job again at 300k.
