I would switch to a full synthetic oil. You're getting a bit of sludge going on there from all that air that was getting in.
“Air that was getting in”? Are you saying you think that air was getting sucked in somewhere it should not have been? I would not think of the valve cover gasket allowing air in, assuming it’s generally under positive pressure especially with a clogged PCV.I would switch to a full synthetic oil. You're getting a bit of sludge going on there from all that air that was getting in.
I really don’t like the way that guy pried on those potentially denying the internal surface using it as a fulcrum and also scratching his screwdriver along the sealing surface. As you can see I made a mess of part of the valve cover, but it’s a part that is completely external to the seal unlike what the dude did in the video.In your pictures where you circled in Red, where you thought it was leaking, is that a port clogged with Carbon? I'd use a pick and clean that out. Make sure you clean the mating surfaces, either use scotch brite kitchen sponge, emory cloth, etc.
To get the tube seals out, 12:00 into the video is an example of how I did them. I have a set of different size prybars like that from HF. Don't worry about scuffing up the outside area of the tube seals, the new ones will seal it. You will need something that is wide enough, a normal screwdriver head will make a mess of it, as you already know.
I did this on both my Accords, my Pilot, and a coworkers Accord and CRV. Yes they were tight, but it was much easier using those prybars than my Lisle Seal puller. The sealing surface in on the inner ring, which goes around the spark plug tube. The outside sealing surfaces that the outer part of the tube seals mates against is not going to affect anything with a little marring. Now, if that were a crank or camshaft seal, you need to be VERY careful with what you are doing, as you mar the cam or crank, you are done, but the outside surfaces, not so much.I really don’t like the way that guy pried on those potentially denying the internal surface using it as a fulcrum and also scratching his screwdriver along the sealing surface. As you can see I made a mess of part of the valve cover, but it’s a part that is completely external to the seal unlike what the dude did in the video.
I say “NO NO” to this guy’s method. If his seals were anywhere as tight and rigid as mine his method wouldn’t even work either because the method requires the seal come out at an angle.
I haven’t done much on the inside of the motor of a car besides tearing down an old MB v8 (removing pistons and crank etc) just to get rid of it. I’ve done the intake manifold gaskets on am old MB, but that was for fun, not for a driver. Working on a daily driver is far more stressful, but parts are far more readily available.I did this on both my Accords, my Pilot, and a coworkers Accord and CRV. Yes they were tight, but it was much easier using those prybars than my Lisle Seal puller. The sealing surface in on the inner ring, which goes around the spark plug tube. The outside sealing surfaces that the outer part of the tube seals mates against is not going to affect anything with a little marring. Now, if that were a crank or camshaft seal, you need to be VERY careful with what you are doing, as you mar the cam or crank, you are done, but the outside surfaces, not so much.
Exactly how much car wrenching experience do you have, and what type of tools do you have at your disposal? I don't want to throw you into the deep end if you have never done this kind of work before.
TOOLS:I
Yeah. I’m a little worried that my oil pan seal is blown out too. Yesterday was a wash out. So I didn’t get a chance to check to see if I solved all my oil leak problems, and today my wife is gone with the car until late tonight. So maybe tomorrow I will discover if I’ve solved my leaks or not.What I was getting at was that the valve cover was no longer sealed, and air was allowed in. This brings moisture and mixes with the oil. Running or not. It does seem that the sludge and the valve cover gasket leaking may be related. As RonnieJ pointed out. You might have more clogged ports causing pressure then you would like. Hopefully the Synthetic oil helps, and don't go to long between oil changes. Especially if the synthetic is knocking lose sludge deposits. I would check your dipstick and if the fluid on it gets thick, you should do another oil change, and not wait for the next service interval.
I will have to study where the PCV sends the air. I guess it makes sense to go through the throttle body.EGR passages and ports, internal oil channels and ports, Throttle body.
Not the same with the 06-08 Pilots and the Ridgeline with the J35A9, than with the 03-05 Pilot engine.EGR passages and ports, internal oil channels and ports, Throttle body.
This video showing the leaks near the crank pulley/oil filter/oil pan could either be needing an oil pump reseal (essentially a TB replacement with a bunch of extra work to reseal the oil pump), or could be the rocker arm control solenoid assembly filter/gasket (easiest and likely first thing to check - what the oil filter is attached to).Yeah. I’m a little worried that my oil pan seal is blown out too. Yesterday was a wash out. So I didn’t get a chance to check to see if I solved all my oil leak problems, and today my wife is gone with the car until late tonight. So maybe tomorrow I will discover if I’ve solved my leaks or not.
You should not be taking your vehicles of this age to a dealer for ANYTHING. If you aren't doing the work yourself with the help from these forums, then look for a reputable local INDY shop that specializes in Honda. Every area has them.TOOLS:
I have been utterly disappointed in the local Honda dealership service. Their parts department is great, but the service center never suggested replacing the PCV. It’s been several years since I’ve taken the car to my brother’s brother-in-law who has an independent shop. He scaled back and doesn’t have any mechanics other than himself.
You looked at one piece of the puzzle on those EGR systems The channels on top were redesigned so they wouldn't build up with carbon, but the ports between the channels and the EGR still does. Many overlook it, and clean the channels and still have the problem, and can't figure out why. It is a circular system. Exhaust to EGR to intake, to cylinder, to exhaust again. Carbon usually builds up between the EGR and the Intake. It is less likely on the later models to clog on both though, but still clogs.Not the same with the 06-08 Pilots and the Ridgeline with the J35A9, than with the 03-05 Pilot engine.
I've seen the posts where people had clogged passages on the 03-05, and when I took off the intake plenum cover, it was a different design on my 07 than on the 03-05. Different grooves, not nearly as susceptible to gumming up with crud. Still wouldn't be that hard to check, but not as critical on his Pilot and Ridgeline with the J35A9.
NailGrease has a boilerplate list of things to do on these, especially for those that just purchased one, and also a good list, with intervals, to look after when doing your own work - ATF drain and fills, front transfer case, VTM drain and fill, brake fluid replacement, power steering flush (with updated O-ring), spark plugs, PCV, air filter and tube (if cracked), MAF/MAP cleaning (depending on year), always the TB every 100k along with waterpump and new coolant, leaks from rocker arm oil control solenoid assembly (replace the gasket), etc..
