I have a 2007 Honda pilot has 188,000 Miles. Lately start blowing white/blue smoke cloud at startup only then clears out. it doesn't loose any coolant. it consumes about (1) Qt of oil every other week (every 300-500 mile). Vehicle is driven pretty much every day. I changed PVC located at the front engine head. Also I have noticed oil in intake manifold concentrated above the third piston in front side (counting from passenger side to driver side). it is soaked in intake body at mentioned location. I need guidance to determine the root cause and a fix plan. Thanks in advance for your help.
You can easily check and clean the egr passages on the top if the engine.
Replace the Pcv valve and clean up all associated hoses.
