1 - 1 of 1 Posts
I recently completed a dashcam installation, and others might find these notes useful.
I mounted my dashcam behind the rear view mirror, and the main issue is getting power to the camera. There are two convenient sources for 12V power:
At first I thought I would use the map light console circuit because it was more convenient. I reverse engineered the power supply circuit for the map light console, but it turns out you can find the circuit diagram with some searching:
Text Diagram Line Design Parallel Electrical wiring Wire Cable Technology Auto part
This circuit can provide an unswitched 12V support, but in the end I decided I didn't want to risk the dashcam draining the battery, so I ended up using the autodimming mirror circuit. The relevant part of the autodimming mirror circuit is this:
Text Line Diagram Parallel Font Technology Wire Auto part Electronic device Automotive lighting
Notice it provides a switched 12V supply (hot when the car ignition is engaged), GND, and also a 12V signal when the reverse gear is engaged. Be aware that when you're checking the wiring with a multimeter, it's easy to confused GND and the reverse gear signal.
To tap into the circuit, I decided to try to find the matching connectors rather than splicing into the wires. After some measuring, and research, I discovered that these are Sumitomo HD 090 series connectors.
I ordered part 6098-0244 and pins and crimped my own matching connector. Suppliers I found include:
  • Code:
    http://www.cycleterminal.com/hd-series.html
    • Cycle Terminal - Sumitomo - HD Non-Sealed Connectors - These Connectors are used highly on Honda car and Motorcycles
  • Code:
    https://www.aliexpress.com/item/33061679811.html?spm=2114.12057483.0.0.58a4e9b0TzTriy
    • JokTheel - Sumitomo HD type 4 Pin way male female unsealed car auto electrical wire connector plug 6098-0244 6098-0243
Lastly remember that these car circuits supply 12V, and to complete the installation the following additional considerations are required:
1 - 1 of 1 Posts
