Looking for some guidance, 06 Pilot 200,000+ miles. Just had the front cv axels replaced and now a couple of times it won’t start, engine won’t even turn over all electrical comes on but nothing else and ideas?
Measure battery voltage. Should be ~12.6Vdc.
Check battery connections; positive and negative.
Check the four (I think) points where the battery positive cable connects to.
Check cables from engine block to chassis.
Another car fubared by the shop? What else is new?
Does your starter at least click? Do you get the cluster lights come on?
Also, were there any signs of something not being quite right before the work was done? Prolonged starting, check engine light, battery light coming on, etc.?
If you get everything lights up on the cluster like normal but nothing ... not even a crank ..try this ..put your foot on the brake .. shift all the way down and back up to park ..turn off then try to start ..if it starts then it's your neutral safety switch.. easy replacement
Reactions: mjm906 and can
