1 - 8 of 8 Posts
The low beam on the driver side of my pilot is not coming on, but the high beam works. I changed the bulb, swapped fuses left and right fuses and both relays and still nothing. The passenger side is fine, just the right. I noticed when I removed the bulb, there was some dust, so I sprayed it out with air. Still isn't working.
Any suggestions? Not terribly mechanically inclined, but willing to try to fix this myself.
That happened to me on my 2003 Pilot. There was a recall that took care of that. Check your Vin to see if you have a recall.
Discussion Starter #3
I should have mentioned that I did check that, but it said my vehicle was not part of that recall. I was hoping that was it, but didn't turn out to be the issue.
There is no recall of any sort for a 14 year old vehicle unless it's a safety item like Air bags , seat belts , or emissions related items. Check the wiring that leads to the bulb to make sure it's not burned off or eaten ..or broken .
Reactions: Sedaitaintso
When did you get this TSB complete ?
Discussion Starter #6
I glanced at the small area that I could see where it attaches to the bulb socket to see if the wires were loose, and I didn't see anything there. I had thought maybe a loose ground wire. I will have to look into it further and trace the wiring to inspect the rest of it. Mybuncle suggested replacing the switch, which I am ok with doing, but I would hate to spend the money and have it be something else. Thank you for the suggestion.
check the switch first cause if it was bad BOTH sides would not function .. so its only that side is the issue .. could be a bad socket that the build sits in .
2008 Honda Pilot EX-L
I'd say check Ground G301 (if you have a multi-meter, can check for continuity from the actual plug itself to the ground point):
140058
140057
140055
140054
1 - 8 of 8 Posts
