I put papers in the back portion of the mildle console and the went behind the sliding door. How can I access it?
Try removing the panel to access and vacuum the rear console blower motor.
https://www.piloteers.org/threads/rear-vent-flow.129882/#post-1348186
Easiest way is to grab the panel where it's near the gas pedal and pull out, popping the clips out that hold it in place, as you work your way to the rear. Hopefully near the gas pedal you'll be able to find what you lost.
