Recently installed hitch with new wire harness. All lights working except brake lights. Not getting brake light juice from vehicle side of the harness. Brake lights on vehicle working. Is there a designated fuse for this? Anyone have access to the wire diagram of the vehicle side of the harness?
Does the hitch harness plug into a factory harness? Or did you have to splice wires? If you had to splice wires I would double check those connections. If you plugged into existing connectors make sure those connectors mated completely.
Also if you are planning to tow the Pilot requires power steering and tranny fluid coolers.
There is a 30 amp fuse that goes in the engine fuse block for the brake lights on the gen 2's that what I had to do .. wondering if it's the same issue here ?
Looking at this site for the 05 they mention nothing about a fuse .. may want to check the fuse boxes
