1 - 19 of 19 Posts
Helping a friend of the family with their 2005 Toyota Corolla this week. The biggest concern for them was the AC stopped working. But you know me, I'm under the hood asking questions cause it's not running so good...
148001
I found oil in the spark plug tubes so you gotta install a new valve cover gasket...
148000
Can't have the coils off without installing a new set of NGK Ruthenium HX plugs for those coughAuto coughLite cough plugs...
148004
Also installed a new PCV valve. The old wire clamp had to go...
148005
Next, tho not an easy task since it is a 6 pulley set up 馃槄, there was a great need to change the drive belt...
148007
After all this and cleaning the MAF, it was doing much better except the to lean engine code I was getting. After some research, I found that these engines are prone to intake manifold leak. So I got the intake off waiting on a RockAuto order for a new gasket....
148008
Reactions: The Todd and aggrex
Nobili spiritus embiggens peque帽o sparus tyre.
And I thought I was OCD. But, man, next time I'm in Texas I wanna drop by so you can give my ride the once over. :)
So the real reason for my checking this vehicle out was the AC. There was no power to the blower motor or the compressor button. After checking all fuses and relays (that were obvious),these checked out ok. Hot wire tested both the compressor and the blower motor. These also proved to be ok. I was concerned about there not being enough freon in the system. The owner said they were having to put freon in once a year. So the search began for a leak and I found this... 馃
148028
Installed a new Denso condenser, charged it with freon and still a no go. At this point I'm thinking I got a short in the wiring, rat attack, something 馃. I begin to dismantle the console, everything checks out. I could see a large bundle of wiring above the glovebox. I decided to remove the entire dashboard, airbag and all. Now I thought Honda had done some dumb stuff over the years, but Toyota gets the prize. After lifting the dashboard off, I found a row of relays just above the glovebox, with no way to access except by removing the dashboard. Seriously Toyota? 馃槨 So there it was, a burned out melted 5 pronged Denso relay...
148030
So I wait patiently for my RockAuto order. I will have to bypass this outlet completely, soldering female quick conections to each wire and just let the new relay hang.
Does that relay switch power to the blower motor, the A/C compressor (clutch) or something else?
Is something such as the blower motor drawing more power than it should, which caused the relay to fail?
Or, if this is the A/C compressor/clutch relay, could a low level of freon have been causing it to turn on and off too frequently?
This obviously is a big break in the power supply. Some very heavy gauge wiring is connected to this relay. I am hopeful that once it's replaced, the power to the fan control and compressor switch will be restore.
Yes, my original assumption was that the low freon was causing the system not to work. That was before I found this hidden relay.
VCM muzzler and Maxlife 3 times ATF drain and fill and all will be good.(y);)
I believe the MaxLife ATF is already in it. 馃榿 The rest of the car will likely fall apart before the engine and transmission. Sadly.
Wow, impressive find. Now I'm making the trip to TX just for that, even if I have to have it towed. :)
Discussion Starter · #11 ·
Welp,
Got the rest of the parts in today to finish up this project.
Since I had the intake manifold off, I noticed the throttle body was a little dirty, so I gave it a good cleaning with CRC and an old toothbrush.
Before and After​
148169
Installed a new throttle body gasket.
148171
Next, got the intake manifold prepped and installed a new gasket.
148173
A little cleaning makes it look nice and new. :p
148175
And now, I'm happy to say that after installing a new 5 prong relay from Standard Motor Products, the AC fan control and the AC compressor button works as designed. I did have to cut the wires out of the relay outlet box and soldier on some connectors, but hey, it's working and the owner is happy. 馃榿馃憤
148177
148178
AC is nice and cool 馃ザ
Returned to owner, but probably do a few more things later on.
Toyota Nation forum 馃か
Traded Pilot for Highlander
This is awesome! You did a great job. How many miles does the Corolla have?
Discussion Starter · #13 ·
Reactions: The Todd
Welp,
Before and After​
Oh No way! I'm not worthy, I'm not worthy, I'm not......
Awesome work!!!!
148188
Reactions: Nail Grease
Discussion Starter · #17 ·
And got his next trick @Nail Grease wil clean up the EGR and PCv systems....
Speaking of the EGR valve on this LE model, @RockAuto sells an EGR valve listed under 2005 Corolla. I finally determined that it doesn't exist on this year model. I really like RA's website, but they really need to do a better job of not offering parts that do not belong on a particular vehicle.
And yes, the PCV valve was replaced too (post #1). 馃榿
Man, that throttle body now looks so clean I'd drink my morning coffee out of it.
148203
Discussion Starter · #19 ·
1 - 19 of 19 Posts
