Replaced both bulbs when I noticed one high beam wasn't working. Didn't solve issue. Moved working passenger bulb low/high to driver side, still only works on low beam. Tested both plugs in low and high beam to verify which prongs light, both plugs work identically and show 13.5 to 14 amps.
I’m guessing you measured volts and if so those numbers appear correct for open circuit voltage.
Is there any corrosion/oxidation on the non working socket?
Do any of the prongs look like they are bent?
Any difference in high beam behavior depending on high beam lever position (pulled towards you vs pushed away from you)?
