21 - 27 of 27 Posts
2005 Pilot EXL
Well, that would be my next move as well... the wheel well. :)
Find solace in the fact that you are not alone.
2006 Pilot Wet Passenger footwell
Interior leak
Ok- after looking at passenger wheel well, I noticed that I forgot to wrap the wiring harness with electrical tape (3Layers). Also lightly coated harness and connectors with silicone caulk. Performed water test - from sunroof & did direct spray on body seam & harness- No Water 😀👍. Now- real test is rain. Was looking forward to last night’s storm (weirdness 😉) to see how she faired- 27 mph winds & .93” of rain. DRY!!!!!!! I found NO WATER INSIDE !!!!! I will leave carpet pulled back on passenger side to keep an eye on it and report back after more rains 😀👍. HAPPY CAMPER & Moving on to Spark Plug Change! THANKS FOR THIS FORUM AND ALL THE HELP!!!!
2005 Honda Pilot LX
Glad to hear the water leak figured out.
Happy for you, and glad you came back to post the fix as a reference for others who may encounter this problem in the future. (y)
2005 Pilot EXL
Ooooohhhh....I'm HERE Baby!!!! :):p Just ordered some plugs from Rock Auto- looks to be an easy job! Can't wait to put them in- 6k past due, but I'm getting 15mpg. Will see if new plugs increase mpg?
2005 Honda Pilot LX
Changing the plugs out is a pretty straight forward job. Figure it will take you a couple hours if it’s your first time. The biggest trick I learned from a previous job was to use a piece of fuel line to get the plugs started to avoid cross threading them into the engine block.
2005 Pilot EXL
Will do! Thanks!! And.. [email protected] 3” extensions for rear plugs is supposed to be the trick
21 - 27 of 27 Posts
